Running an hypervisor in Armv8-R AEM FVP platform, hypervisor mode, aarch32. While trap and emulating an MMIO region where the supervisor mode guest emits an STRD instruction (targetting a region protected by the 2nd stage MPU), HSR.ISS comes up "empty". That is, despite ELR_hyp, HDFAR and HSR.EC being correct, HSR.ISS.ISV is 0. Therefore, I don't have sufficient information to decode and emulate the access. I guess it would be possible to decode the instruction "by hand", but I don't understand why this is happening. Can you imagine any reason why this information is not there? Should I expect this in real hardware? Could this possibly be some kind of bug or issue with the model?
Bumping up the thread. Can anyone at point me to elsewhere I could get this question answered?
Can you expose more details about what are the "HDFAR and HSR.EC being correct"? What is HSR.IL?
v8-R ARM.ARM says HSR.ISS is all RES0 for ISS encoding for Exceptions with an unknown reason.
Execution in any Non-secure PE mode other than Hyp mode makes this HSR register UNKNOWN.
If all the SW potential issues can be filtered out, maybe we can check the Armv8-R AEM FVP further.
So can you decode dataabort from HSR.EC? If yes can you check the STRD instruction is postindex or preindex when it was accessing MMIO address? A postindex STRD access will cause an invalid dataabort in VMM, VMM must decode the guest instructions to handle it.
Thanks for your response.
Zhifei Yang said:Can you expose more details about what are the "HDFAR and HSR.EC being correct"? What is HSR.IL?
HDFAR is correct because it shows me the correct address the strd instrution is trying to access and HSR.EC is correct because it contains the correct exception cause, i.e. "Data Abort from a lower Exception level.". HSR.IL it is also set correctly on the exception, i.e., it indicates the faulting instruction is 32-bit.
Zhifei Yang said:v8-R ARM.ARM says HSR.ISS is all RES0 for ISS encoding for Exceptions with an unknown reason
That is why I stressed HSR.EC is correct. The reason is not unkonwn, it is a "Data Abort from a lower Exception level" at the address contained in HDFAR.
Zhifei Yang said:Execution in any Non-secure PE mode other than Hyp mode makes this HSR register UNKNOWN.
I don't get what is your point here. My code is executing at Hyp mode.
weichen said:So can you decode dataabort from HSR.EC?
Yes, EC is set to "Data Abort from a lower Exception level"
weichen said:If yes can you check the STRD instruction is postindex or preindex when it was accessing MMIO address?
I think neither. Here is the disassembly for the instruction that causes the exception:
100014b0: e18340f0 strd r4, [r3, r0]
In this case, have you tried to upgrade your local Armv8-R AEM FVP to the latest release version, e.g.11.18?
Just upgraded from 11.17.32 to 11.18.16 but the issue persists
STRD could not work with an unaligned address (64-bits alignment required). Can you check the memory address alignment?
The accessed address is 0xaf006128. It seems to fulfill that aligment. To be more detailed, maybe this can help you help me: the guest is trying to access a gic distributor router register.
From Arm ARM, ISS encoding for exception from a Data Abort. For ISV, bit [24]
This bit is 0 for all faults except Data Aborts generated by stage 2 address translations for which all the following apply to the instruction that generated the Data Abort exception:
• The instruction is an LDR, LDA, LDRT, LDRSH, LDRSHT, LDRH, LDAH, LDRHT, LDRSB, LDRSBT, LDRB, LDAB, LDRBT, STR, STL, STRT, STRH, STLH, STRHT,STRB, STLB, or STRBT instruction.• The instruction is not performing register writeback.• The instruction is not using the PC as a source or destination register
It seems STRD/LDRD are not in the instructions list that can generate valid syndrome.
It seems you are right. I assumed it would apply also to ldrd/strd given that EC.SAS field has a enconding for doubleword accesses on aarch32.
Thank you for helping me figure this out!
Just for completeness... I should have checked this before, but Linux gicv3 driver files for 32-bit arm have the explicit answer to this question in this exact case (ie access to gicd.irouter register):
/* * Even in 32bit systems that use LPAE, there is no guarantee that the I/O * interface provides true 64bit atomic accesses, so using strd/ldrd doesn't * make much sense. * Moreover, 64bit I/O emulation is extremely difficult to implement on * AArch32, since the syndrome register doesn't provide any information for * them. * Consequently, the following IO helpers use 32bit accesses. */ static inline void __gic_writeq_nonatomic(u64 val, volatile void __iomem *addr) { writel_relaxed((u32)val, addr); writel_relaxed((u32)(val >> 32), addr + 4); }
The GIC function's comment is very clear. Two traps are more simpler than decode invalid dataabort and emulate 64-bit IO.
Glad to be of help!
