Is DSU PMU supported in FVP Cortex-A73x4 A53x4 ?
I was trying to test DSU (DynamIQ Share Unit) PMU (Performance Monitor Unit) with the example PMU_Aarch64-FVP_Cortex-A73x2-A53x4 project coming with Arm Development Studio R1.0, and I always get SyncError exception. I did modifiy the Start.S to set bit 12 of ACTLR_EL3 and ACTLR_EL2, but no help. Could anyone help on this to see why?
Xiaoming
  • Hi Xiaoming,
    could you give me some more details of how you built the example, and how you ran it?
    I followed the instructions in the README file in the example to build the software, then launch the simulation from the Arm DS IDE.  It worked and produced the expected results.
    The PMU is partially implemented in the DSU in the Fast Models.  However, please note that the results will not be the same as those you will get in hardware, as Fast Models & FVPs are functional (Programmer's View) models and do not implement the micro-architectural details of the CPU
  • Hi Rob,
    The example coming with DS-5 is testing PMUs for each core. I have no issues to run it. What I wanted to test is cluster PMUs inside DSU. I got exception when executing the first instruction MRS to read CLUSTERPMCR_EL1 register in following sequence:
    EL1N:0x0000000080002E7C : MRS x8,S3_0_C15_C5_0
    EL1N:0x0000000080002E80 : MOV x9,#0x46
    EL1N:0x0000000080002E84 : MOV w10,#0xffffffff
    EL1N:0x0000000080002E88 : BFXIL x8,x9,#0,#7
    If PMU is partially implemented in FVP, this is understood.
  • Hi Xiaoming, I overlooked this in my earlier answer.  The Cortex-A73 and Cortex-A53 pre-date the introduction of the DSU concept.  Each cluster has it's own L1 + L2 and can snoop the other CPU's cache through a cache-coherent interconnect (e.g. CCI550).  The DSU PMU registers will therefore not be present in the FVP that you are using.
    The DSU was first introduced with the Cortex-A75 and Cortex-A55 cores.
