USB HID Demo on mcbstm32
I'm trying to run the Keil example for the above board.
1/ I've moved J1 jumper to PD2.
2/ I built the software, but Uvision (3.8a) would not download it to the board ( siguv3arm.dll problem /).
3/ On a forum I discovered that you had to create a new project and 'import' all the example source code.
This worked, and the LCD displayed MCBSTM32 HID.
4/ I've connected the board to my PC ( windows xp) via the USB lead. Sometimes it comes up with 'new device' etc. I told it that its a hid.
5/ I've run the hidclient.exe program, but it does not display the board. For device it displays <None>
6/ How can I get the above client to talk to my board ?
  • Hello Martin Guenther.
    1/ The board is connected through its JTAG connector to the ULINK2 and the USB connector to the PC.
    I'm not running it in debug mode.
    2/ Under Devices there are several entries under Human Interface Devices.
    There is one labelled HID-compliant consumer control device.
    There are two labeled HID-compliant device.
    There are hree labeled USB Human Interface Device ( 2 of these are the keyboard and the other the ULINK).
    So i'm not sure which one applies to the ST board so that I can uninstall it ?
