Hello I am using microVision2 V2.40. When I'm trying to open the project file I have a following get this message Can't read project project file 'ProjectFileName'!. Anyone had similar problems?
I made the changes you mention in uVision 5, Edit>Configuration>Editor>General Editor Setting>Enconding (I tested the two option Chinese) but no changes occur, the problem is not solved, I get the same problem. Also, comments with Chinese characters inside .C files do not display well.
What's the Windows OS installed?
windows 7 x64
My recommendation:
- in general (and strongly recommended): Update to Windows 10
- configure 'Unicode' at uVisions Configuration/Editor/General Editor Settings/Encoding
