Hi,I am working on Galaxy S3, Exynos quad-core, 1.4 GHz quad-core Cortex-A9 with MALI-400 MP.The device is using Android Jelly Bean. Linux/arm version is Linux/arm 3.0.31 Kernel.While using profiling (streamline) in DS-5, GPU snippets are not showing."Chart configuration is incompatible with this configuration is showing when GPU counters are selected.Before that, I built gator.ko and gatord and copied them into same directory in target.Using DS-5, I can get CPU performance counters but not GPU counters.I even generated gator.ko with "GATOR_WITH_MALI_SUPPORT=MALI-400".Can anyone kindly guide me about where are we missing something.Thanks a lot.Yasir.
Hi Yasir, welcome to the forum!You may have a typo in your definition of GATOR_WITH_MALI_SUPPORT. This should be set to 'MALI_400' (not MALI-400). The rest looks ok.We only currently have gator working for Mali under ICS. We've not yet tried Jellybean but there's no reason I can think of that would prevent this from working too.Give this a go and let us know how you get on...Many thanks,Mark
The error "Chart configuration is incompatible with this capture" usually occurs when the counter that is to be displayed from the chart configuration was never captured. Generally there is a more explicit error message with the tooltip that might say something like "Missing source data: X"
Hi Yasir, Medge, Any updates on the issue. I am also facing exactly the same problem, except that my issue is on Nexus 10(MALI-T604). If you could share the solution/status for this issue, it could well solve my issue as well.thanks and regards,Karthick
