Hi all,
Is it possible to Enable/Disable L2 cache on ARM Cortex-A72? If yes could you please guide on how to do that?
Thanks a lot.
Yes, but only together with L1 (see manual).
Hi Schick, I follow A72 TRM and do following step:
Set Bit C and I of SCTLR_EL1 to 0
Invalidate ICache
Flush and Invalidate DCache
May I know if this is enough or any other step is needed? I still can observe the timing increase a lot when I perform those steps.
Btw, one more question, after I disable L1/L2 cache, I still set up MMU, is there any issue? Thanks.
Chanh said:I still set up MMU, is there any issue?
I don't see any.
Chanh said:I still can observe the timing increase a lot when I perform those steps.
Timing increase after disabling the cache? For sure. That's what caches are for!
Hi Schick,
Got it. Thanks.
