ARM MDK can't list CMSIS-DAP Debugger with 2 WINUSB IFs
Hi sir,
I have tried to create my own CMSIS DAPLink debugger with 2 WINUSB IFs for that my board has 2 MCUs and I am ableo to debug them at the same time.
And I have sucessfully implemented the USB device with 2 IFs and can be found on WIN10 device manager window like below:
But on Keil MDK only the last IF (Channel 1) is available:
But at the same time, the IAR listed two IFs and every one worked well:
It seems that the driver CMSIS_DAP.dll can't list all IFs and only the last IF is avalialbe.
Refer to the DAP USB Config below:
https://www.keil.com/pack/doc/CMSIS_Dev/DAP/html/group__DAP__ConfigUSB__gr.html
Update String Settings - Product String to indicate the Debug Unit. Note that "CMSIS-DAP" must be part of that string to allow identification by debuggers (or part of interface string for USB composite device).
And the first IF's string is "CMSIS-DAP CH0" and the second IF's string is  "CMSIS-DAP CH1".
So Keil should have listed all IFs instead of only the last one. The source of the driver CMSIS_DAP.dll is not opened, so would you like to enhenced this problem?
Thanks in advance.
