Corba ARM
I am looking into using Corba Objects for an ARM project that I have.
I am using the Windows Keil compiler (microvision 4) and would like to know if anyone
can give me any advice on using Corba in ARM projects.
thank you
  • It doesn't matter if you use ARM or some other processor.
    And the Keil compiler will handle standard C/C++ code, so it isn't really a deciding factor either.
    The main thing to consider, is if you like to use dynamic memory or not - and how you look at the danger of heap fragmentation, given the normally huge difference in the heap size on embedded devices compared to a normal PC.
    So instead of asking about CORBA on an ARM, you should spend your time considering CORBA on an embedded device. It's the "embedded" that's the important part.
