Hi
I am using stm32f103RBT6 Microcontroller For sending timestamp in millisecond through usb to a receiver . The program works fine when when i am testing in keil uvision before sending through usb but after sending through usb in receiver software it's missing a event (sometime it does lose event and sometimes not). Can anyone please tell me where the problem can be ? the code is too long to pçst here so i can't upload the whole program. Will really appreciate any help. Thanks
Here is the Fifo stack part
typedef struct FifoStack { u16 u16EventTimeStampMSPart; //This variable have only the ms part!!! u32 u32EventTimeStamp; // This variable have only the s part!!! u8 u8EventInput; } SFIFO_STACK; // Private function prototypes ------------------------------------------------- void UsbConnect(void); void StackPush(u32 u32EventTime, u16 u16EventTimeMS, u8 u8Input); u8 StackPop(SFIFO_STACK *psFifoStack); void GetMessage(u8 *pu8Buffer); void TaskFilter(void); // ***************************************************************************** /// @brief Function that saves an event in cell /// @fn void StackPush(u32 u32EventTime, u16 u16EventTimeMS, u8 u8Input) /// @param[in] u32EventTime @brief Event time /// @param[in] u16EventTimeMS @brief Event time, ms part ASIF /// @param[in] u8Input @brief Entry number that generated the event // ***************************************************************************** void StackPush(u32 u32EventTime, u16 u16EventTimeMS, u8 u8Input) { if ((s16StackWriteIndex + 1) != s16StackReadIndex) // checks for stack space { sFifo[s16StackWriteIndex].u16EventTimeStampMSPart = u16EventTimeMS; //saves the time stamp on the stack, part MS sFifo[s16StackWriteIndex].u32EventTimeStamp = u32EventTime; // saves the time stamp on the stack sFifo[s16StackWriteIndex].u8EventInput = u8Input; //saves the digital input on the stack s16StackWriteIndex++; // incrementing the write index if (s16StackWriteIndex >= STACK_SIZE) // make circular written index s16StackWriteIndex = 0; } } // ***************************************************************************** /// @brief Function that retrieves a cell event /// @fn u8 StackPop(SFIFO_STACK *psFifoStack) /// @param[out] psFifoStack @brief Event /// @retval TRUE, se ok // ***************************************************************************** u8 StackPop(SFIFO_STACK *psFifoStack) { if (s16StackReadIndex != s16StackWriteIndex) // checks for data on the stack { psFifoStack->u16EventTimeStampMSPart = sFifo[s16StackReadIndex].u16EventTimeStampMSPart; //search timestamp cell, part MS psFifoStack->u32EventTimeStamp = sFifo[s16StackReadIndex].u32EventTimeStamp; // search timestamp cell psFifoStack->u8EventInput = sFifo[s16StackReadIndex].u8EventInput; // search the digital input cell number s16StackReadIndex++; // incrementing the read index if (s16StackReadIndex >= STACK_SIZE) // make the reading rate is circular s16StackReadIndex = 0; return TRUE; } else return FALSE; }
I posted a image here
www.electro-tech-online.com/.../
This is the code for receiver software
Communication file
#include "communication.h" #include <QStringList> #include "msgbox.h" #include "hiddevice.h"
Communication::Communication() { thread = new QThread(); mutex; rcv = new Reception((QObject*)this); rcv->moveToThread(thread); connect(this,SIGNAL(Rx_Again()),rcv,SLOT(doWork())); }
void Communication::StartRX() { if(thread->isRunning() == false) thread->start(); QMetaObject::invokeMethod(rcv, "doWork", Qt::QueuedConnection); }
int Communication::ConfigPort(QByteArray Str) { return serial.Init(0x483,0x473); }
int Communication::Recv() { int res = 0; if(mutex.tryLock()) { res = serial.Read(32); mutex.unlock(); } return res; }
void Communication::CallRxAgain() { emit Rx_Again(); }
int Communication::SaveRXdata() { return 0; }
void Communication::ComRX() { emit Rx_Finish(); }
void Communication::Send(Packet* data) { int err; // serial.ClearBufferTX(); memset(&serial.bufferTX,0,HidDevice::BUFFER_SIZE); memcpy(&serial.bufferTX[0], data->Pack()->data(), data->Pack()->size()); err = serial.Write(serial.bufferTX, 32);
void Communication::ClosePort() { serial.Close(); }
QByteArray Communication::getRX_Data() { QByteArray res = QByteArray((char*)serial.bufferRX,31); return res; }
void Communication::run() {
Communication::~Communication() { if(thread->isRunning()) thread->deleteLater(); }
/****************************** M'todo para recep''o dos dados ********************************/ Reception::Reception(QObject* t) { comclass = t; }
/**************************** M'todo para recep''o dos dados *****************************/ void Reception::doWork() { int recvBytes = -1; while( (recvBytes = ((Communication*)comclass)->Recv()) < 0 ) { if (recvBytes < 0) printf("RecvBytes < 0 !!!"); }
((Communication*)comclass)->ComRX(); }
Hid device File
HidDevice::HidDevice() { memset(&bufferTX[0], 0, BUFFER_SIZE); memset(&bufferRX[0], 0, BUFFER_SIZE); }
// ***************************************************************************** /// @brief Inicializa a HID /// @fn int SerialPort:: Init(QByteArray s) /// param[in] QByteArray s /// @brief Serial port address /// retval SProcess Status: Failed-1; 0-Success // ***************************************************************************** int HidDevice::Init(unsigned short vendor_id, unsigned short product_id) { int res; #define MAX_STR 255 wchar_t wstr[MAX_STR]; // Open the device using the VID, PID, // and optionally the Serial number. handle = hid_open(vendor_id, product_id, NULL); // res = hid_get_manufacturer_string(handle, wstr, MAX_STR); // qDebug("Manufacturer String: %s\n", wstr); // Read the Product String res = hid_get_product_string(handle, wstr, MAX_STR); qDebug("Product String: %ls\n", wstr); hid_set_nonblocking(handle,0);
if(handle==0) return 0; else return 1; }
void HidDevice::Close() { if (handle > 0) hid_close(handle);
int HidDevice::Read(void) { return Read(BUFFER_SIZE); }
int HidDevice::Read(int nb) { int n_bytes_rx = 0, timeout_flag = 1; // HidDevice::ClearBuffers(); memset (bufferRX, 0, nb);//zera o buffer de recepcao timeout_flag = hid_read(handle, bufferRX, nb); if (timeout_flag < 0) n_bytes_rx = TIMEOUT; return n_bytes_rx; }
int HidDevice::Write(unsigned char *buffer_tx, int n_bytes) { int counter; counter = hid_write(handle, buffer_tx, n_bytes); return counter; }
