Dear Sir/Madam I have a MCB1700 board and i want to control its LEDs via pc via TCP/ip.in order to do it i used LEDswitch program but i read the help and it suggests to use a specific windows application for control the LEDs via LAN cable and pc.in this case the board is a server and PC is a client. How can i find this windows application ? can i use command prompt window instead of windows application?if yes please help me how to use it. Also please give me some help for configuring my LEDswitch program codes on my board.
Thank you
Subnet mask? Isn't that where you enter the IP of one of Google's DNS servers? :p
subnet mask is used for dividing a network to two or more network.in this case i could use 255.255.255.0 .but my issues doesn't solve with it.Do you have another idea?
i could use default number 255.255.255.0.but by this configuration my problem doesn't solve.Do you have any idea for solving the issue?
So you should be familiar with some tools & techniques for debugging IP network issues - what have you tried?
In particular, what have you done to determine whether this is a PC issue, an IP issue, or an issue at the mcb1700 end?
Is the cable correctly wired for that?
One suspects it's not a cross-over cable.
This is generally why I use a switch or router. And in circumstances where I want to monitor traffic I'd use an old HUB device which reflects traffic to another box for analysis, either just using a card in promiscuous mode, or a box running WireShark
Unfortunately it is clear that you know how the TCP/IP protocol stack uses the information.
Stop playing around with things you don't understand. Set it to what it was before. Otherwise you're likely to not see any success even if you were to find and fix the original problem.
yes.Also i used another cable but the problem wasn't solve
i used original project code (LEDSwitch) and didn't apply any change to it but the problem wasn't solve. How can i send the project code to you for more considering?
"yes. Also i used another cable but the problem wasn't solve"
Yes to what?
Perhaps you work with someone who has more Windows/IT/Networking experience? The guys with those Microsoft Certs rather than real engineering degrees.
Two PC/laptops connected through a switch would at least demonstrate network functioning, at the moment you have the system complaining TCP/IP networking doesn't work, and I haven't seen a IPCONFIG output suggesting otherwise.
I've got dozens of "other" ethernet cables, they are mostly all straight through as that's what people typically make/buy, I've got another box of "special" cross-over cables that do something else.
Is the cable correctly wired for that? i said yes to your question. i connect my LAN cable to two PCs and the communication was stablished then i disconnected it from PCs and connected it to mcb1700 and my laptop but LEDswitch.exe couldn't work and show me prior error.
But when i connect my Ethernet cable to mcb1700 and my laptop i can run HTTPDemo project on board and can simply control the board .Can you describe more about your own cross-over cable?
"Couldn't connect. Please check the TCP/IP setting of your PC"
But you've got source code for both ends of the transaction, can't you refine your understanding of the problem a little bit better? What errors/failures on the PC side would cause it to throw the error? Can you replicate that with WINSOCK based code that performs the equivalent function?
" i said yes to your question"
Well, you made a post that started with the word "yes" - but you didn't indicate what specific question it was in reply to!
" i connect my LAN cable to two PCs and the communication was stablished"
But do your PCs auto-detect the connection type...?
