Hi Team,
MediaTek Dimensity 9000 SOC uses the latest ARM Mali GPU G710. We see that they mentioned about embedded processor in the GPU susbystem which offloads the CPU workload.
HC2022.Mediatek.EricbillWang.v08.pptx (hotchips.org) - Slide 14 from this link explains the details.
We wanted to know more details about this emebedded processor. Can the OEM's or SOC vendor's modify the GPU subsystem ?
Thanks and Regards
Shashidhar
shashidharskv said:We wanted to know more details about this emebedded processor. Can the OEM's or SOC vendor's modify the GPU subsystem ?
The command stream frontend subsystem is just considered part of the GPU IP, so it is not publicly documented nor modifiable by the OEM.
Cheers,Pete
So the claim from the Mediatek of
"From G78 to G710 there is -15% GPU driver loading on CPU by offloading to embedded processor"
is from command stream frontend subsystem introduced in the G710 GPU architecture ?
Or there is a new processor inside this G710 IP ?
shashidharskv said:is from command stream frontend subsystem introduced in the G710 GPU architecture ? Or there is a new processor inside this G710 IP ?
Yes and yes =)
The command stream frontend (CSF) substantially changes how the driver talks to the hardware, and reduces CPU load significantly (by more than 15% for many applications, but it's content dependent). The CSF includes an embedded processor, but there is far more to it than that in terms of domain-specific hardware assist. It's not a public part of the architecture, so that's about as much detail as I can give here.
Cheers,
Pete
