"Not A PKM FIle" Exception
Note: This was originally posted on 24th June 2013 at http://forums.arm.com
I use Mali Texture Compression to convert a JPG image to a PKM file, no mipmaps.
And then I put the PKM file into the raw folder of my Android Project, and load it in my android java code via ETC1Utils, running on Samsung Note2, but it reports "Not A PKM File" exception.
Again, I load it via libGDX, it still reports "Not A PKM File" exception.
Is there something I missed in converting?
  • Note: This was originally posted on 1st July 2013 at http://forums.arm.com
    Hi LostAbaddon,
    Do you have a reproducer app that we could test on our end?
    [size=2]This will help us identify what the problem is, what the solution may be, and any workarounds that may be of use.[/size]
    [size=2]
    [/size]
    [size=2]Thanks in advance,[/size]
    [size=2]
    [/size]
    [size=2]McGeagh[/size]
  • Note: This was originally posted on 5th July 2013 at http://forums.arm.com
    Can you also let us know the version of:
    [color=#444444][font=arial][size=2] - Mali Texture Compression version.[/size][/font][/color]
    [color=#444444][font=arial][size=2] - Android.[/size][/font][/color]
    Are you using the terminal or the eclipse application to compress the texture?
  • Note: This was originally posted on 29th July 2013 at http://forums.arm.com
    LostAbaddon
    Hi LostAbaddon,
    Can you let us know if you have fixed the problem?
