So I modified the make file like that since the mali driver source code is located in that path.=======================================================================KCFLAGS="-I../../../mail400_driver/driver/src/devicedrv/mali"GATOR_WITH_MALI_SUPPORT=MALI_400=======================================================================
Instead of fixing the error perfectly, I simply copied the 'mali_linux_trace.h' into gator-driver folder and modified the gator-driver source code since the 'mali_linux_trace.h' is linked when building.
Hey Sanjung,
I'm running into the same problem as you, but I have many files that are not found. After I move the mali_linux_trace.h like you did, another file was shown as not found.
I am wondering, did you move all the required files to your driver directory? Did you end up getting this working with DS-5 Streamline?
Thanks!
