Weird SPSR behaviour
I was trying to write a register context saving/restoring when I came across a weird behaviour.
My code (sorry, tried to format tens of times, but the editor WANTS to make asm a table):
asm volatile (
"pop {r0 - r3}"
"push {r0 - r3}"
"mov r0, r3"
"bl dbg_out" - outputs 60000013
"pop {r0 - r3}"
"msr cpsr_fsxc, r2"
"@dsb"
"@isb"
"msr spsr_fsxc, r3" - set value
"@dsb"
"@isb"
"mov lr, r1"
"mov sp, r0"
"push {r0 - r4, lr}"
"mov r0, lr"
"bl dbg_out"
"mov r0, sp"
"bl dbg_out"
"mrs r2, cpsr"
"mrs r3, spsr" - read value
"mov r0, r2"
"bl dbg_out"
"mov r0, r3" - outputs 00000002
"bl dbg_out"
When the exception is returned from, the calling function:
asm volatile ("svc #0\n\t");
    msg = "returned from SVC\r\n";
    serial_io.put_string(msg, util_str_len(msg)+1);
    asm volatile (
"mrs %[retreg], cpsr\n\t"
:[retreg] "=r" (tmp1) ::
    msg = "cpsr = ";
    util_word_to_hex(scratchpad, tmp1);
    serial_io.put_string(scratchpad, 9);
    serial_io.put_string("\r\n", 3);
outputs "returned from SVC" and "cpsr = 60000013".
Why the "00000002"? the barriers don't seem to have any effect.
