ARM 7 TDMI
Hello I am  new to this forum and new to Arm 7 programming.
My question is - I have a programming (I think it is a Flash) file in hex ,which I downloaded to Arm 7 MCU through Rlink usb tool to run the programme.
If I need to modify this programme how do I do this?
  • There are two possible answers to your question...but it sounds like you have a lot of background on embedded development to make up!
    - If you have the source code, you can recompile the program and generate a new binary (hex) file which you  can then download.
    - If you don't have the source code, then it is obviously much harder and you are restricted just to changing a few instructions via the debugger. But that will only work if the program is running in RAM.
    Hope this helps.
    Chris
  • How do I find out whether the program is running in RAM?
  • What sort of debugger program you recommend to do this task?
  • If the dis-assembly code can be generated, is it match your intention? If it is enough, I will provide the following code.
    #include <stdio.h>
    FILE *fp;
    main(int argc, char *argv[])
    int ch;
    int pos=0;
    fp = fopen(argv[1], "rb");
    printf(".text\n");
    printf("main:\n");
    while((ch=fgetc(fp))!=EOF){
      if(pos==0){
      printf(".byte\t");
      printf("0x%02x",ch&0xff);
      if(pos==7){
      pos=0;
      printf("\n");
      else{
      printf(",");
      pos++;
    fclose(fp);
    This is to convert a binary code to an assembler source.
    By using the objcopy command, you can get binary file corresponding to the hex file.
    You can assemble the source file and get dis-assembly code by using the objdump command.
    The following is an example.
    $ cat tmp.hex
    S00A0000746D702E68657831
    S11380006400A0E3FFFFFFEA010050E3940000DAFC
    S11380100030A0E3F04F2DE93CD04DE200308DE577
    S1138020020050E38100000A023040E218308DE57E
    S113803003B0A0E10030A0E304308DE5033040E25A
    S11380400130C3E3040040E2003063E024308DE5F6
    S113805001005BE30B30A0E1830000DA0020A0E321
    S113806030B08DE508208DE5020053E36B00000A73
    S1138070022043E21C208DE502B0A0E10020A0E331
    S11380800C208DE5032043E20120C2E3043043E2E7
    S1138090033062E028308DE501005BE30B30A0E1A2
    S11380A05C0000DA0020A0E334B08DE510208DE5FB
    S11380B0020053E35300000A022043E220208DE52E
    S11380C002A0A0E10020A0E314208DE5032043E2F8
    S11380D00120C2E3043043E2033062E02C308DE53A
    S11380E001005AE30A30A0E1440000DA0090A0E362
    S11380F0020053E33E00000A02B043E20B60A0E139
    S11381000070A0E3038043E20180C8E3043043E24B
    S1138110038068E0010056E30640A0E1320000DA83
    S11381200050A0E3010044E2B6FFFFEB024044E24A
    S1138130010054E3005085E0F9FFFFCA015085E2D5
    S1138140026046E2080056E1057087E0F0FFFF1A7E
    S1138150017087E201005BE30B30A0E1079089E046
    S1138160E2FFFFCA019089E22C309DE502A04AE2B9
    S113817003005AE114309DE5093083E014308DE5A5
    S1138180D6FFFF1A019083E220309DE510209DE583
    S1138190010053E3092082E010208DE5C3FFFFCAEC
    S11381A034B09DE5013082E228209DE502B04BE227
    S11381B002005BE10C209DE5033082E00C308DE58C
    S11381C0B4FFFF1A012083E21C309DE508109DE5F1
    S11381D0010053E3022081E008208DE5A1FFFFCADE
    S11381E030B09DE5013082E2200000EA0150A0E3B6
    S11381F0D2FFFFEA0170A0E300B0A0E3D4FFFFEADE
    S11382000190A0E3D7FFFFEA0030A0E30190A0E3D0
    S113821020308DE5DCFFFFEA0130A0E3E1FFFFEA57
    S11382200030A0E30120A0E31C308DE5E6FFFFEA67
    S11382300020A0E30130A0E318208DE5010052E303
    S11382400200A0E100209DE5033082E000308DE5CE
    S113825072FFFFCA010083E23CD08DE2F04FBDE81B
    S11382601EFF2FE10100A0E31EFF2FE10130A0E378
    S113827024209DE502B04BE202005BE104209DE571
    S1138280033082E004308DE570FFFF1A013083E291
    S10B829018209DE5E8FFFFEA58
    S90380007C
    $ ../gcc-arm-none-eabi-4_9-2014q4-20141203-win32/bin/arm-none-eabi-objcopy -I srec -O binary tmp.hex tmp.bin
    $ ./bin2src tmp.bin > tmp.s  # This is the command shown above
    $ cat tmp.s
    .text
    main:
    .byte   0x64,0x00,0xa0,0xe3,0xff,0xff,0xff,0xea
    .byte   0x01,0x00,0x50,0xe3,0x94,0x00,0x00,0xda
    .byte   0x00,0x30,0xa0,0xe3,0xf0,0x4f,0x2d,0xe9
    .byte   0x3c,0xd0,0x4d,0xe2,0x00,0x30,0x8d,0xe5
    .byte   0x02,0x00,0x50,0xe3,0x81,0x00,0x00,0x0a
    .byte   0x02,0x30,0x40,0xe2,0x18,0x30,0x8d,0xe5
    .byte   0x03,0xb0,0xa0,0xe1,0x00,0x30,0xa0,0xe3
    .byte   0x04,0x30,0x8d,0xe5,0x03,0x30,0x40,0xe2
    .byte   0x01,0x30,0xc3,0xe3,0x04,0x00,0x40,0xe2
    .byte   0x00,0x30,0x63,0xe0,0x24,0x30,0x8d,0xe5
    .byte   0x01,0x00,0x5b,0xe3,0x0b,0x30,0xa0,0xe1
    .byte   0x83,0x00,0x00,0xda,0x00,0x20,0xa0,0xe3
    .byte   0x30,0xb0,0x8d,0xe5,0x08,0x20,0x8d,0xe5
    .byte   0x02,0x00,0x53,0xe3,0x6b,0x00,0x00,0x0a
    .byte   0x02,0x20,0x43,0xe2,0x1c,0x20,0x8d,0xe5
    .byte   0x02,0xb0,0xa0,0xe1,0x00,0x20,0xa0,0xe3
    .byte   0x0c,0x20,0x8d,0xe5,0x03,0x20,0x43,0xe2
    .byte   0x01,0x20,0xc2,0xe3,0x04,0x30,0x43,0xe2
    .byte   0x03,0x30,0x62,0xe0,0x28,0x30,0x8d,0xe5
    .byte   0x5c,0x00,0x00,0xda,0x00,0x20,0xa0,0xe3
    .byte   0x34,0xb0,0x8d,0xe5,0x10,0x20,0x8d,0xe5
    .byte   0x02,0x00,0x53,0xe3,0x53,0x00,0x00,0x0a
    .byte   0x02,0x20,0x43,0xe2,0x20,0x20,0x8d,0xe5
    .byte   0x02,0xa0,0xa0,0xe1,0x00,0x20,0xa0,0xe3
    .byte   0x14,0x20,0x8d,0xe5,0x03,0x20,0x43,0xe2
    .byte   0x03,0x30,0x62,0xe0,0x2c,0x30,0x8d,0xe5
    .byte   0x01,0x00,0x5a,0xe3,0x0a,0x30,0xa0,0xe1
    .byte   0x44,0x00,0x00,0xda,0x00,0x90,0xa0,0xe3
    .byte   0x02,0x00,0x53,0xe3,0x3e,0x00,0x00,0x0a
    .byte   0x02,0xb0,0x43,0xe2,0x0b,0x60,0xa0,0xe1
    .byte   0x00,0x70,0xa0,0xe3,0x03,0x80,0x43,0xe2
    .byte   0x01,0x80,0xc8,0xe3,0x04,0x30,0x43,0xe2
    .byte   0x03,0x80,0x68,0xe0,0x01,0x00,0x56,0xe3
    .byte   0x06,0x40,0xa0,0xe1,0x32,0x00,0x00,0xda
    .byte   0x00,0x50,0xa0,0xe3,0x01,0x00,0x44,0xe2
    .byte   0xb6,0xff,0xff,0xeb,0x02,0x40,0x44,0xe2
    .byte   0x01,0x00,0x54,0xe3,0x00,0x50,0x85,0xe0
    .byte   0xf9,0xff,0xff,0xca,0x01,0x50,0x85,0xe2
    .byte   0x02,0x60,0x46,0xe2,0x08,0x00,0x56,0xe1
    .byte   0x05,0x70,0x87,0xe0,0xf0,0xff,0xff,0x1a
    .byte   0x01,0x70,0x87,0xe2,0x01,0x00,0x5b,0xe3
    .byte   0x0b,0x30,0xa0,0xe1,0x07,0x90,0x89,0xe0
    .byte   0xe2,0xff,0xff,0xca,0x01,0x90,0x89,0xe2
    .byte   0x2c,0x30,0x9d,0xe5,0x02,0xa0,0x4a,0xe2
    .byte   0x03,0x00,0x5a,0xe1,0x14,0x30,0x9d,0xe5
    .byte   0x09,0x30,0x83,0xe0,0x14,0x30,0x8d,0xe5
    .byte   0xd6,0xff,0xff,0x1a,0x01,0x90,0x83,0xe2
    .byte   0x20,0x30,0x9d,0xe5,0x10,0x20,0x9d,0xe5
    .byte   0x01,0x00,0x53,0xe3,0x09,0x20,0x82,0xe0
    .byte   0x10,0x20,0x8d,0xe5,0xc3,0xff,0xff,0xca
    .byte   0x34,0xb0,0x9d,0xe5,0x01,0x30,0x82,0xe2
    .byte   0x28,0x20,0x9d,0xe5,0x02,0xb0,0x4b,0xe2
    .byte   0x02,0x00,0x5b,0xe1,0x0c,0x20,0x9d,0xe5
    .byte   0x03,0x30,0x82,0xe0,0x0c,0x30,0x8d,0xe5
    .byte   0xb4,0xff,0xff,0x1a,0x01,0x20,0x83,0xe2
    .byte   0x1c,0x30,0x9d,0xe5,0x08,0x10,0x9d,0xe5
    .byte   0x01,0x00,0x53,0xe3,0x02,0x20,0x81,0xe0
    .byte   0x08,0x20,0x8d,0xe5,0xa1,0xff,0xff,0xca
    .byte   0x30,0xb0,0x9d,0xe5,0x01,0x30,0x82,0xe2
    .byte   0x20,0x00,0x00,0xea,0x01,0x50,0xa0,0xe3
    .byte   0xd2,0xff,0xff,0xea,0x01,0x70,0xa0,0xe3
    .byte   0x00,0xb0,0xa0,0xe3,0xd4,0xff,0xff,0xea
    .byte   0x01,0x90,0xa0,0xe3,0xd7,0xff,0xff,0xea
    .byte   0x00,0x30,0xa0,0xe3,0x01,0x90,0xa0,0xe3
    .byte   0x20,0x30,0x8d,0xe5,0xdc,0xff,0xff,0xea
    .byte   0x01,0x30,0xa0,0xe3,0xe1,0xff,0xff,0xea
    .byte   0x00,0x30,0xa0,0xe3,0x01,0x20,0xa0,0xe3
    .byte   0x1c,0x30,0x8d,0xe5,0xe6,0xff,0xff,0xea
    .byte   0x00,0x20,0xa0,0xe3,0x01,0x30,0xa0,0xe3
    .byte   0x18,0x20,0x8d,0xe5,0x01,0x00,0x52,0xe3
    .byte   0x02,0x00,0xa0,0xe1,0x00,0x20,0x9d,0xe5
    .byte   0x03,0x30,0x82,0xe0,0x00,0x30,0x8d,0xe5
    .byte   0x72,0xff,0xff,0xca,0x01,0x00,0x83,0xe2
    .byte   0x3c,0xd0,0x8d,0xe2,0xf0,0x4f,0xbd,0xe8
    .byte   0x1e,0xff,0x2f,0xe1,0x01,0x00,0xa0,0xe3
    .byte   0x1e,0xff,0x2f,0xe1,0x01,0x30,0xa0,0xe3
    .byte   0x24,0x20,0x9d,0xe5,0x02,0xb0,0x4b,0xe2
    .byte   0x02,0x00,0x5b,0xe1,0x04,0x20,0x9d,0xe5
    .byte   0x03,0x30,0x82,0xe0,0x04,0x30,0x8d,0xe5
    .byte   0x70,0xff,0xff,0x1a,0x01,0x30,0x83,0xe2
    .byte   0x18,0x20,0x9d,0xe5,0xe8,0xff,0xff,0xea
    $ ../gcc-arm-none-eabi-4_9-2014q4-20141203-win32/bin/arm-none-eabi-gcc -o tmp2.out tmp.s -nostdlib
    d:/gcc-arm-none-eabi-4_9-2014q4-20141203-win32/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: warning: cannot find entry symbol _start; defaulting to 00008000
    $ ../gcc-arm-none-eabi-4_9-2014q4-20141203-win32/bin/arm-none-eabi-objdump -D tmp2.out
    tmp2.out:     file format elf32-littlearm
    Disassembly of section .text:
    00008000 <main>:
        8000:       e3a00064        mov     r0, #100        ; 0x64
        8004:       eaffffff        b       8008 <main+0x8>
        8008:       e3500001        cmp     r0, #1
        800c:       da000094        ble     8264 <main+0x264>
        8010:       e3a03000        mov     r3, #0
        8014:       e92d4ff0        push    {r4, r5, r6, r7, r8, r9, sl, fp, lr}
        8018:       e24dd03c        sub     sp, sp, #60     ; 0x3c
        801c:       e58d3000        str     r3, [sp]
        8020:       e3500002        cmp     r0, #2
        8024:       0a000081        beq     8230 <main+0x230>
        8028:       e2403002        sub     r3, r0, #2
        802c:       e58d3018        str     r3, [sp, #24]
        8030:       e1a0b003        mov     fp, r3
        8034:       e3a03000        mov     r3, #0
        8038:       e58d3004        str     r3, [sp, #4]
        803c:       e2403003        sub     r3, r0, #3
        8040:       e3c33001        bic     r3, r3, #1
        8044:       e2400004        sub     r0, r0, #4
        8048:       e0633000        rsb     r3, r3, r0
        804c:       e58d3024        str     r3, [sp, #36]   ; 0x24
        8050:       e35b0001        cmp     fp, #1
        8054:       e1a0300b        mov     r3, fp
        8058:       da000083        ble     826c <main+0x26c>
        805c:       e3a02000        mov     r2, #0
        8060:       e58db030        str     fp, [sp, #48]   ; 0x30
        8064:       e58d2008        str     r2, [sp, #8]
        8068:       e3530002        cmp     r3, #2
        806c:       0a00006b        beq     8220 <main+0x220>
        8070:       e2432002        sub     r2, r3, #2
        8074:       e58d201c        str     r2, [sp, #28]
        8078:       e1a0b002        mov     fp, r2
        807c:       e3a02000        mov     r2, #0
        8080:       e58d200c        str     r2, [sp, #12]
        8084:       e2432003        sub     r2, r3, #3
        8088:       e3c22001        bic     r2, r2, #1
        808c:       e2433004        sub     r3, r3, #4
        8090:       e0623003        rsb     r3, r2, r3
        8094:       e58d3028        str     r3, [sp, #40]   ; 0x28
        8098:       e35b0001        cmp     fp, #1
        809c:       e1a0300b        mov     r3, fp
        80a0:       da00005c        ble     8218 <main+0x218>
        80a4:       e3a02000        mov     r2, #0
        80a8:       e58db034        str     fp, [sp, #52]   ; 0x34
        80ac:       e58d2010        str     r2, [sp, #16]
        80b0:       e3530002        cmp     r3, #2
        80b4:       0a000053        beq     8208 <main+0x208>
        80b8:       e2432002        sub     r2, r3, #2
        80bc:       e58d2020        str     r2, [sp, #32]
        80c0:       e1a0a002        mov     sl, r2
        80c4:       e3a02000        mov     r2, #0
        80c8:       e58d2014        str     r2, [sp, #20]
        80cc:       e2432003        sub     r2, r3, #3
        80d0:       e3c22001        bic     r2, r2, #1
        80d4:       e2433004        sub     r3, r3, #4
        80d8:       e0623003        rsb     r3, r2, r3
        80dc:       e58d302c        str     r3, [sp, #44]   ; 0x2c
        80e0:       e35a0001        cmp     sl, #1
        80e4:       e1a0300a        mov     r3, sl
        80e8:       da000044        ble     8200 <main+0x200>
        80ec:       e3a09000        mov     r9, #0
        80f0:       e3530002        cmp     r3, #2
        80f4:       0a00003e        beq     81f4 <main+0x1f4>
        80f8:       e243b002        sub     fp, r3, #2
        80fc:       e1a0600b        mov     r6, fp
        8100:       e3a07000        mov     r7, #0
        8104:       e2438003        sub     r8, r3, #3
        8108:       e3c88001        bic     r8, r8, #1
        810c:       e2433004        sub     r3, r3, #4
        8110:       e0688003        rsb     r8, r8, r3
        8114:       e3560001        cmp     r6, #1
        8118:       e1a04006        mov     r4, r6
        811c:       da000032        ble     81ec <main+0x1ec>
        8120:       e3a05000        mov     r5, #0
        8124:       e2440001        sub     r0, r4, #1
        8128:       ebffffb6        bl      8008 <main+0x8>
        812c:       e2444002        sub     r4, r4, #2
        8130:       e3540001        cmp     r4, #1
        8134:       e0855000        add     r5, r5, r0
        8138:       cafffff9        bgt     8124 <main+0x124>
        813c:       e2855001        add     r5, r5, #1
        8140:       e2466002        sub     r6, r6, #2
        8144:       e1560008        cmp     r6, r8
        8148:       e0877005        add     r7, r7, r5
        814c:       1afffff0        bne     8114 <main+0x114>
        8150:       e2877001        add     r7, r7, #1
        8154:       e35b0001        cmp     fp, #1
        8158:       e1a0300b        mov     r3, fp
        815c:       e0899007        add     r9, r9, r7
        8160:       caffffe2        bgt     80f0 <main+0xf0>
        8164:       e2899001        add     r9, r9, #1
        8168:       e59d302c        ldr     r3, [sp, #44]   ; 0x2c
        816c:       e24aa002        sub     sl, sl, #2
        8170:       e15a0003        cmp     sl, r3
        8174:       e59d3014        ldr     r3, [sp, #20]
        8178:       e0833009        add     r3, r3, r9
        817c:       e58d3014        str     r3, [sp, #20]
        8180:       1affffd6        bne     80e0 <main+0xe0>
        8184:       e2839001        add     r9, r3, #1
        8188:       e59d3020        ldr     r3, [sp, #32]
        818c:       e59d2010        ldr     r2, [sp, #16]
        8190:       e3530001        cmp     r3, #1
        8194:       e0822009        add     r2, r2, r9
        8198:       e58d2010        str     r2, [sp, #16]
        819c:       caffffc3        bgt     80b0 <main+0xb0>
        81a0:       e59db034        ldr     fp, [sp, #52]   ; 0x34
        81a4:       e2823001        add     r3, r2, #1
        81a8:       e59d2028        ldr     r2, [sp, #40]   ; 0x28
        81ac:       e24bb002        sub     fp, fp, #2
        81b0:       e15b0002        cmp     fp, r2
        81b4:       e59d200c        ldr     r2, [sp, #12]
        81b8:       e0823003        add     r3, r2, r3
        81bc:       e58d300c        str     r3, [sp, #12]
        81c0:       1affffb4        bne     8098 <main+0x98>
        81c4:       e2832001        add     r2, r3, #1
        81c8:       e59d301c        ldr     r3, [sp, #28]
        81cc:       e59d1008        ldr     r1, [sp, #8]
        81d0:       e3530001        cmp     r3, #1
        81d4:       e0812002        add     r2, r1, r2
        81d8:       e58d2008        str     r2, [sp, #8]
        81dc:       caffffa1        bgt     8068 <main+0x68>
        81e0:       e59db030        ldr     fp, [sp, #48]   ; 0x30
        81e4:       e2823001        add     r3, r2, #1
        81e8:       ea000020        b       8270 <main+0x270>
        81ec:       e3a05001        mov     r5, #1
        81f0:       eaffffd2        b       8140 <main+0x140>
        81f4:       e3a07001        mov     r7, #1
        81f8:       e3a0b000        mov     fp, #0
        81fc:       eaffffd4        b       8154 <main+0x154>
        8200:       e3a09001        mov     r9, #1
        8204:       eaffffd7        b       8168 <main+0x168>
        8208:       e3a03000        mov     r3, #0
        820c:       e3a09001        mov     r9, #1
        8210:       e58d3020        str     r3, [sp, #32]
        8214:       eaffffdc        b       818c <main+0x18c>
        8218:       e3a03001        mov     r3, #1
        821c:       eaffffe1        b       81a8 <main+0x1a8>
        8220:       e3a03000        mov     r3, #0
        8224:       e3a02001        mov     r2, #1
        8228:       e58d301c        str     r3, [sp, #28]
        822c:       eaffffe6        b       81cc <main+0x1cc>
        8230:       e3a02000        mov     r2, #0
        8234:       e3a03001        mov     r3, #1
        8238:       e58d2018        str     r2, [sp, #24]
        823c:       e3520001        cmp     r2, #1
        8240:       e1a00002        mov     r0, r2
        8244:       e59d2000        ldr     r2, [sp]
        8248:       e0823003        add     r3, r2, r3
        824c:       e58d3000        str     r3, [sp]
        8250:       caffff72        bgt     8020 <main+0x20>
        8254:       e2830001        add     r0, r3, #1
        8258:       e28dd03c        add     sp, sp, #60     ; 0x3c
        825c:       e8bd4ff0        pop     {r4, r5, r6, r7, r8, r9, sl, fp, lr}
        8260:       e12fff1e        bx      lr
        8264:       e3a00001        mov     r0, #1
        8268:       e12fff1e        bx      lr
        826c:       e3a03001        mov     r3, #1
        8270:       e59d2024        ldr     r2, [sp, #36]   ; 0x24
        8274:       e24bb002        sub     fp, fp, #2
        8278:       e15b0002        cmp     fp, r2
        827c:       e59d2004        ldr     r2, [sp, #4]
        8280:       e0823003        add     r3, r2, r3
        8284:       e58d3004        str     r3, [sp, #4]
        8288:       1affff70        bne     8050 <main+0x50>
        828c:       e2833001        add     r3, r3, #1
        8290:       e59d2018        ldr     r2, [sp, #24]
        8294:       eaffffe8        b       823c <main+0x23c>
    Disassembly of section .ARM.attributes:
    00000000 <.ARM.attributes>:
       0:   00001341        andeq   r1, r0, r1, asr #6
       4:   61656100        cmnvs   r5, r0, lsl #2
       8:   01006962        tsteq   r0, r2, ror #18
       c:   00000009        andeq   r0, r0, r9
      10:   01090108        tsteq   r9, r8, lsl #2
    Cannot it help you?
    Best regards,
    Yasuhiko Koumoto.
  • Thanks for your instructions. I'll try this and let you know the result.
  • i, I reccommend GCC ARM Embedded in Launchpad as the dis-assembler (i.e. objdump) because some the other dis-assembler could not dis-assemble successfully the elf code generated by my procedure. It seems to be good.
    Best regards,
    Yasuhiko Koumoto.
  • Can you explain this process in a simple way pls.
  • Hello,
    the basic idea are the folowings.
    1) to generate a source code from the hex file.
       If you can use an ICE, it would be very easy.
    2) to modify the source code as you like.
    3) to compile the modified source code.
    4) to convert the compiled binary to a hex file.
    That's all.
    Best regards,
    Yasuhiko Koumoto.
