i apply the ip of CortexM0,get the files:
i write a testbench:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY AHBLITE_SYS_vhd_tst IS
constant CLKPeriod: time := 10 ns;
END AHBLITE_SYS_vhd_tst;
ARCHITECTURE AHBLITE_SYS_arch OF AHBLITE_SYS_vhd_tst IS
SIGNAL CLK : STD_LOGIC:='0';
SIGNAL LED : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL RESET : STD_LOGIC:='0';
COMPONENT AHBLITE_SYS
PORT (
CLK : IN STD_LOGIC;
LED : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
RESET : IN STD_LOGIC );
END COMPONENT;
BEGIN
i1 : AHBLITE_SYS PORT MAP ( CLK => CLK, LED => LED, RESET => RESET );
simProcess: process
begin
RESET <= '0'; wait for 40 ns;
RESET <= '1' ; wait for 1000 ns;
RESET <= '1' ; wait;
end process simprocess;
ClockProcess: process(CLK, RESET)
if (RESET = '0') then CLK <= '0';
else CLK <= not CLK after CLKPeriod;
end if;
end process ClockProcess;
END AHBLITE_SYS_arch;
i run it in quartus 11.0
but the simulation run into a err:
我找人帮你看看
工程师帮忙看了,你的问题有些不太清楚,请问你的Error是什么,没有看懂。或者能否请你把Error的信息发出来看一下。
