DS-5 debug on Marvell PCE errors/warnings
I am using Dstream with a Pactron sherwood board with Marvell armada xp, since there isnt an existing platform in DS-5 I tried PCE and got warnings about several components not having a connection e.g. CSTFunnel. I read in another discussion that could be caused if I ran the PCE in uboot, since it only powers on one core. So I got linux to run and did the configuration again but with same results.
My goal is to debug u-boot and kernel, so I can figure out how to switch the kernel to big endian properly(as I understand u-boot doesnt need to be BE). Due to some limitations in the u-boot, I have to make the switch in kernel.
So, do these warnings only limit the trace and linux application debug? Or also the bare metal? I have tried just proceeding with the warning and I can make a connection but I run into trouble when I try to set a break point and step through u-boot.
I am very new to this environment please do let me know if I can provide further information?
  • Hi,
    I would start by using PCE to create a configuration containing a single core + its CTI. You need to choose the core that will run uboot - probably core_0 but you may have to experiment a bit. Then connect DS-5 to just that core and see if you get more success and a stable debug environment. If uboot only uses this one core and you dont need trace capability you will have all you need for uboot debug.
  • Hi,
    Just to add some further questions to my colleague Lukas's tutorial links....
    I understand that the Pactron Sherwood board uses a Marvell MV78460 Quad-core  ARM v7-compliant processor.
    If this is correct, then I am intrigued as to how the processor identifies itself, are you able to share this with us ?
    The processor is designed by Marvell (rather than ARM) so it may behave slightly differently to how we might expect when debugging.
    Can you also tell us in a bit more detail please what is happening when you do try to set a breakpoint, single-step u-boot ?
    Thanks,
    Stuart
  • Hi,
    Thank you for the suggestions. I havent watched those videos as it seems like, yes, core_0 is the active core. I can connect to it but its unable to find the entry point, also it doesnt seems to stop at any breakpoints.
    I am trying to debug the problem where u-boot is in little endian and kernel is compiled in a big endian. U-boot hangs with "Starting kernel ..." message.
  • Please see my reply to Lukas's answer. I will try to add in as I go.
    I was able to get a debug platform, with warnings, using the PCE. Which as I understand should be sufficient for debug but not trace.
    That's correct.
    So it doesn't stop at any breakpoints then ? Are these hardware ones or software ones ?
  • Either or.
    Using breakpoints I can stop the execution before from when I boot up the board till autoboot countdown start in u-boot.
    The other way I was able to stop was using watchpoints for addresses that I know will be accessed.
    The reason that I understand so far is because the u-boot has an additional header or two(specific to Marvell)  before the main u-boot gets executed, and that the main code is at an offset from the headers. So the symbol file needs to be loaded again with an offset.
    I have tried the offset that I think is correct using PC and the disassembly, which seems to work. I used a HW breakpoint to stop at the do_bootm_linux and then carefully step through till u-boot enters kernel.
    Everything seems to be in order for me to be able to debug the big endian kernel.
    Thank you all for the input.
  • Excellent mahmad, thanks for letting us know and I'll bear your answer in mind for any future queries like this.
    Regards,
    Stuart
