Is it safe to use 6.16.2 safety compiler with C++17 ( community) ?
Does the community version makes it any less safe?
HiMy name is Stephen and I work at Arm.Sorry, the "C++17 (Community)" feature is not qualified for FuSa use.Please refer to the AC6.16.2 FuSa Safety Manual for more information.developer.arm.com/.../6-16-2LTSalso says:The command-line option descriptions and related information in the Arm Compiler Reference Guide describe all the features that Arm Compiler for Embedded FuSa supports. Any features not documented are not supported and are used at your own risk. You are responsible for making sure that any generated code using community features is operating correctly. See Support level definitions. Stephen
