Unable to configure the DTSL
I am unable to configure the DTSL.
Can somebody help me with this.
  • Hi Thej,
    Sorry about the delay in getting a response to you on this. I arranged to get your post moved into a new thread of it's own.
    Firstly, what version of DS-5 are you using ?
    If you are trying to capture trace then you need to chose which buffer the trace data is going to be stored in,either an on-chip trace buffer such as an ETB (Embedded Trace Buffer) or an off-chip buffer such as the DSTREAM 4GB trace buffer.
    You do this using the drop-down box by 'Trace Capture Method'  and then selecting which trace capture buffer to use.
    Then click on the tabs to enable trace on either the Cortex-R5 or cortex-M3, whichever is appropriate and available.
    Under the 'Cortex-R5' tab you should see individual tick-boxes for each Cortex-R5 on the platform to enable trace on Cortex-R5_0, Cortex-R5_1 and Cortex-R5_2 (I have now been able to find the platform that is I believe the same as yours).
    The configuration database entry looks quite old, if you are using DS-5 v5.29(.1) then it may be worthwhile to re-import the configuration db and re-test.
    If you are having problems with this then please let me know with some more specifics and I will try to help.
    Again, please accept my apologies in the delay in getting back to you on this.
    Regards,
    Stuart Hirons
