Hey Guys,
First of all, I'm a total beginner on arm programming so I'm sorry if what I'm asking is too obvious or something like that.
So, I want to make some analysis with my L2 cache disabled. I'm running an U-boot environment, bare-metal, on my BeagleBone black and I'm trying to disable the cache following the steps provided on:
https://developer.arm.com/documentation/ddi0344/k/level-2-memory-system/enabling-and-disabling-the-l2-cache-controller
My code is something like this:
asm volatile("MRC p15, 0, %0, c1, c0, 0\t\n": "=r"(controlRegister)); //Retrieve Control Register controlRegister = controlRegister & ~(1u << 2); //change Bit C to 0; asm volatile ("MCR p15, 0, %0, c1, c0, 0\t\n" :: "r"(controlRegister)); //write new value
I know this is only the first step(disable C bit), but I'm having trouble accomplishing it. The problem is, when i try to write the new value and then check if it was write correctly, the value retrieved is 00000000.
Am I doing something wrong? Is there some kind of access level that I need to have to accomplish it? If so, how can I do it?
Regards,
Lucas Cunha
Hello
You would need to be in a privileged mode:https://developer.arm.com/documentation/ddi0344/k/programmers-model/operating-modes
This is best achieved by a SW Interrupt:https://developer.arm.com/documentation/ddi0344/k/programmers-model/exceptions/software-interrupt-instruction
First of all, thanks for the fast reply.
I still don`t understand the concepts of "privileged mode".
On the link provided it's said that "Supervisor mode is a protected mode for the OS", since I'm not using an OS, just a bootloader, shouldn't this concept not apply?
If enter in "supervisor mode" is still a need on bare-metal, do I need to write a SWI handler or there is some generic function numbers that are used exclusively to make this mode change action?
UPDATE: I've been trying to enter the supervisor mode without any success, but then I decided to look on my current operation mode accessing the CPSR and checking the [4-0] bits, as mentioned here . And, according to the CPSR I'm already on unsecured supervisor mode(10011), which seems to be a privileged mode. But I'm still unable to write effectively on Control Register (C1).
So I've tried to go from unsecured to secured mode, but according to the docs I can only access and change the NS-bit if I'm on secure mode...
UPDATE 2: I'm able to retrieve the content of C1 Control Register, but for some reason my program stays hanging when I try to write a new value back on the register.
The value I'm trying to write is 0x00C50879, which is the equivalent of disabling I and C bits.
Any suggestions?
