I read a chapter about encoding Arm instructions, and I can figure out that the 32-bit code for
instruction MOVS r2, #0x01 is 0xF45F 0201. What are the 32-bit codes for instructions
ADDS r3, r1, r2, and BX lr?
BQL said:I read a chapter
So which chapter, exactly, did you read?
Give a proper reference!
If you can figure the first one out, where are you stuck with the 2nd one?
BQL said:What are the 32-bit codes for instructions ADDS r3, r1, r2, and BX lr
You could easily answer that by getting the assembler to do it for you!
Either follow Andy's tip or take a reference manual. They all list the opcodes.
Thank you very much Bastian and Andy. Yes, it helps.
