SoC Design and Simulation blog Free Live Webinar: How to optimize a system with the latest ARM DynamIQ
  • SoC Implementation
  • System Guidance
  • DynamIQ
  • webinar
Hannah
Hannah
June 9, 2017
Less than one minute read time.
Designing SoCs is tricky and the performance of your product depends highly on an array of complicated decisions. To guide our partners through the SoC design process, ARM recently announced system guidance – a free resource for ARM partners. System guidance gives partners access to ARM’s knowhow, allowing them to produce performant products, despite their complex criteria.
Want to know more? Join our free webinar!
Join this webinar with Tom Conway, who will give more detail about the newest System Guidance for Mobile packages. The webinar will discuss guidance available for the new ARM DynamIQ processors (ARM Cortex-A75 and Cortex-A55), plus the new ARM Mali-G72 GPU. In this webinar, which is the second in our SoC performance series, Pete Hawkins will describe the second tip for maximising SoC performance exploring how to Maximise System Bandwidth. This webinar will discuss the challenges of distributing system traffic between multiple LPDDR4 memory channels.
Watch the webinar here
    Tony Nip
    Tony Nip
    • June 30, 2025
    Vincent Yang
    Vincent Yang
    • June 5, 2024
  • Introduction to AMBA Viz
    Tony Nip
    Tony Nip
    • May 31, 2024
