I have "Corstone-500 Preconfigured(BP318)" and "Cortex-A5 MPCore with Neon/FPU/ETM(MP008)".
and I use Linux(CentOS Linux 7). and I installed the tools requested by "Arm® Cortex®-A5 DesignStart SSE-500 Example Subsystem"
I want install and render Corstone SSE-500 on Linux.
But, I have Error Message on intalling SSE-500.
------------------Terminal Message (do Install SSE-500)---------------------
(omitted)
sent 473,766 bytes received 659 bytes 948,850.00 bytes/sectotal size is 471,548 speedup is 0.99sending incremental file listrsync: change_dir "/home/soc/SSE500/TM115-BU-00000-r3p2-00rel1/coresight_soc/shared/logical/cortexa5integration" failed: No such file or directory (2)
sent 20 bytes received 12 bytes 64.00 bytes/sectotal size is 0 speedup is 0.00rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1179) [sender=3.1.2]sending incremental file listrsync: change_dir "/home/soc/SSE500/TM115-BU-00000-r3p2-00rel1/coresight_soc/shared/logical/cortexa5integration/components" failed: No such file or directory (2)
(the rest omitted)
--------------------Terminal Message end--------------------
So, I tried to Find TM115-BU-00000. but I could not find it.
("Corstone-500 Preconfigured(BP318)" and "Cortex-A5 MPCore with Neon/FPU/ETM(MP008)". even "Arm Developer Page"...)
And, I tried to Rendering, But have Error Message too.
------------------Terminal Message (do Render SSE-500)---------------------
Error: Problem occured in generating 'sse500_example'See: /home/soc/SSE500/workspace/sse500_example.canvas/generate-log/sse500_example.log
Info: Writing log sse500_example.canvas/generate-log/configuration.yaml.logInfo: System generate completeExit: 256
------------------------ sse500_example.log------------------
Checking config rules : /home/soc/SSE500/workspace/sse500.ip/logical/config/sse500.php.rules
Creating : /home/soc/SSE500/workspace/sse500_example.canvas/sse500_example/logical/sse500_subsystem/ipxact/arm.com/DesignStart/sse500_subsystem_example1.xml
Traceback (most recent call last): File "/home/soc/SSE500/workspace/sse500.ip/logical/shared/tools/bin/open_files_sse500.py", line 74, in <module> with open(prj_path_file, 'rb') as f:FileNotFoundError: [Errno 2] No such file or directory: '/home/soc/SSE500/workspace/sse500_example.canvas//ca5/logical/CSCTI/verilog/CSCTI.v'
--------------------sse500_example.log end--------------------
So
1. Please let me know if there is any way to get the IP of TM115.
2. (If 1 does not work) Please tell me a way to make installing and rendering work normally.
Thank you and have a nice day!
