I've just downloaded DS-MDK v5.27.0 which adds support for Vybrid VF61 and Toradex Colibri module (which uses this device).
I opened the supplied <Colibri-VF61] Blinky_M4> example and I noticed there is a "Path Entry Problem":
the Includes refer to an absolute path <D:/WORK/freertos-colibri-vf61>.
I suppose this folder should contain the freertos porting for Colibri module distributed by Toradex.
The project can be built, so I don't know if the project really needs these files.
I suggest either to remove the includes (if not needed) or to fix the path (if needed).
Hi Vix, thanks for reporting this issue. I asked the development team to remove the absolute paths in future releases of the VF61 CMSIS Pack.
Best Regards,Stefano
