Flexnet license support in MDK-ARM 6
Hi, we have an active floating Flexnet license which we have been using with MDK-ARM 5 for years.
Can this license be used for MDK-ARM 6 too somehow? As the vscode environment does not seem to allow these kind of licenses to be entered.
Otherwise, do I need a new license for MDK-ARM 6 or can I migrate the existing one?
Regards,
Javier.
  • Hi Javier,
    If you have an existing license, I believe it will pick it up as defined by the ARMLMD_LICENSE_FILE environment variable.
    Alternatively you can activate a free (for non-commercial use) license within VS Code if you just wish to try it out.
    Regards, Ronan
