Hello! I am using Analog Device's ADUCM355 chip.
I am trying to program using Keil's examples, but when I try to build the code, I keep getting the error message "64KSRAM.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST."
How can I resolve this issue?"
You have not shown everything, but I suspect that the init code is not actually being linked into the application.
Can you add --keep init.o (set as appropriate) to the linker command line.
Which compiler are you using to build the image? If using Arm Compiler 5, you cannot use CMSIS6, which I see is selected in your Run Time Environment Manager.
I am using Arm Compiler 6. I added the code to the linker command line, but the same error keeps occurring...
How can I resolve this issue..??
You would set this in the Target Options
I've changed the settings, but the error still occurs.
Also, when changing the settings, the '--keep init.o' added to the linker command line is removed.
Try adding --entry __vector_table to the linker Misc controls.
It may also be useful to look at the object file of that startup file (fromelf -c) to make sure that the ELF section is indeed named RESET. Are you using link time optimization?
