MDK-Arm Community version with license, has no license?
hi
struggling to make a Keil version work to code up an STM32 dev board.  Couple days on the license part now, followed directions, have an active license, even shows up in the help/about page.  Try alot of things and still does not work.  There is a license, just got one, and its the community edition?
Try to compile?  Error: C9555E: Failed to check out a license.
The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.
ARMLMD_LICENSE_FILE is not set. You must set this to the path to your license.
