Once I've updated uVision by Keil with MDK 5.39 release, I'm not able any more to see from Pack Installer the updates of one packet that I store in a packet repository on my factory's network.
The only way I found out to recover was the following: launch the previous pack installer (MDK5.38a), which sees properly the updated packet, and then launch again the new pack installer.
Do you know the reason?
Thank you
Regards
Whats the result after re-installing that Pack with the MDK 5.39 Pack Installer?
I didn't try to reinstall. Now being the packet installer working properly, I'm a little bit afraid to re-install it and take the risk of breaking it.
if you look at the path to the repository, are there any spaces in the path?
If so, try removing the space, or keep using the 5.38 pack installer.
Yes, I'm aware of it and it changed the path, removing spaces. But the resolution of the issue described in this post required a second patch, that I described above: " launch the previous pack installer (MDK5.38a), which sees properly the updated packet, and then launch again the new pack installer."
