Hi there,
We are trying to run code in Keli and just keep gettting this error:
The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.ARMLMD_LICENSE_FILE is not set. You must set this to the path to your license.
How do we go about setting the license??
Thanks in advance
Hello, I moved your query to the Keil specific forum.
In the uVision IDE, have you set up any license in File > License Management? Perhaps a screenshot of what you see displayed may help.
It may be better to raise an official support case from the support menu above, so that you can share any serial numbers etc you have been given.
I agree with my colleague Ronan Synnott - Please open a Support Ticket and confirm there the license key.
https://www.arm.com/support/contact-support
FYI - more information about the ARMLMD_LICENSE_FILE can be found here:
"How does FlexNet find a license file?"
https://developer.arm.com/documentation/dui0577/f/Bihdhedj
