Hi everyone,
I’m struggling here to make an SPI-code work . Preformatted textMy circuit contains the following hardware:
Preformatted text
MAX31865: Datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/max31865.pdf
NUCLEO -F767ZI: Datesheet: NUCLEO-F767ZI | Mbed
RTD-Sensor
Since the MAX31865 requires SPI protocol I wrote this code to read my RTD-data:
#include “mbed.h” SPI spi(PB_5, PB_4, PB_3); // mosi, miso, sclk DigitalOut cs(PA_4); int main() { // Chip must be deselected cs = 1; // Setup the spi for 8 bit data, high steady state clock, // second edge capture, with a 1MHz clock rate spi.format(8, 1); spi.frequency(1000000); // Select the device by seting chip select low cs = 0; // Send a dummy byte to receive the contents of the WHOAMI register int x = spi.write(0x00); printf("register = 0x%X\n", x); // Deselect the device cs = 1; }
Does someone know why I’m not getting any data?
best regard,Ezzow
