When executing this code on cortex M3
#include <stdatomic.h> void atomic_swap () { _Atomic int a = 5; int b = 5; if ( true == atomic_compare_exchange_strong ( & a, & b, 5) ) __breakpoint ( 2 ); // this is never reached }
why atomic_compare_exchange_strong () does not return true and hit the __breakpoint () ?
'a' and 'b' are equal so according to https://en.cppreference.com/w/c/atomic/atomic_compare_exchange 'true' should be returned.
If the program hits the breakpoint, atomic_compare_exchange_strong() did return "true" according to your code snippet. You are checking for "true == true" in this case which makes the if-statement become true.
"If the program hits the breakpoint" - it does not.
