I've been trying to process speech on a stm32f407ve development board for some time now, which makes me wonder if the adc is really set up to precisely sample the values. CMSIS FFT Functions. But when I try to couple it with the ADC in continuous conversion to sample a sine signal, it doesn't seem to sample well periodically. I put a sine signal into it from a frequency test of a 1khz sine wave from an internet video with a plug that I take out of some headphones, which by the way I already tested that it works correctly with an oscilloscope. So... this one from the development board is obviously not from a DSP but its adc should work correctly for this type of applications ?.Here my code, obviously I made sure that the test was emitting voltage before the debug
#include "main.h" #include "arm_math.h" #include "arm_const_structs.h" /* Private includes ----------------------------------------------------------*/ /* USER CODE BEGIN Includes */ /* USER CODE END Includes */ /* Private typedef -----------------------------------------------------------*/ /* USER CODE BEGIN PTD */ #define Fs 4096; /* USER CODE END PTD */ /* Private define ------------------------------------------------------------*/ /* USER CODE BEGIN PD */ /* USER CODE END PD */ /* Private macro -------------------------------------------------------------*/ /* USER CODE BEGIN PM */ /* USER CODE END PM */ /* Private variables ---------------------------------------------------------*/ ADC_HandleTypeDef hadc1; /* USER CODE BEGIN PV */ #define SIGNAL_BUFFER_LENGTH 4096 float signalBuffer[2*SIGNAL_BUFFER_LENGTH]; float fftBuffer[2*SIGNAL_BUFFER_LENGTH]; float magnitudes[SIGNAL_BUFFER_LENGTH]; /* USER CODE END PV */ uint32_t k; uint32_t cont1,cont2; uint32_t start; uint32_t stopi; uint32_t delta; float32_t maxValue; /* Max FFT value is stored here */ uint32_t maxIndex; float frecuencia=10.0; float32_t Ts; float tiempo; /* Private function prototypes -----------------------------------------------*/ void SystemClock_Config(void); static void MX_GPIO_Init(void); static void MX_ADC1_Init(void); /* USER CODE BEGIN PFP */ /* USER CODE END PFP */ /* Private user code ---------------------------------------------------------*/ /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ /** * @brief The application entry point. * @retval int */ int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ #define ARM_CM_DEMCR (*(uint32_t*)0xE000EDFC) #define ARM_CM_DWT_CTRL (*(uint32_t*)0xE0001000) #define ARM_CM_DWT_CYCCNT (*(uint32_t*)0xE0001004) if(ARM_CM_DWT_CTRL !=0){ ARM_CM_DEMCR |= 1<<24; ARM_CM_DWT_CYCCNT =0; ARM_CM_DWT_CTRL |= 1<<0; } /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_ADC1_Init(); /* USER CODE BEGIN 2 */ Ts=1.0/(float)Fs; HAL_ADC_Start(&hadc1); for(k=0;k<2*SIGNAL_BUFFER_LENGTH;k+=2 ) { signalBuffer[k]=HAL_ADC_GetValue(&hadc1); } k++; //signalBuffer[0]=0; //start= ARM_CM_DWT_CYCCNT; arm_cfft_f32(&arm_cfft_sR_f32_len4096,signalBuffer,0,1); signalBuffer[0]=0; arm_cmplx_mag_f32(signalBuffer,magnitudes,4096); arm_max_f32(magnitudes, 4096, &maxValue, &maxIndex); //stopi = ARM_CM_DWT_CYCCNT; //delta=stopi-start; //tiempo=delta/8.0E07*1000.0; /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ }
