Allocate all remaining RAM to HEAP?
I am trying to find a way to allocate all remaining RAM in my application to the heap. Basically a variable heap size that will allow the use of all available memory. I have tried different things with the scatter file, but keep running into needing to specify a size.
I would like the RAM memory map to look like this:
RAM Base Address:
  • Vector table
  • Initialized variable data
  • Zero data
  • Stack (fixed size)
  • Heap (all remaining memory)
Processor: STM32L552
Tools: uVision 5
Existing Scatter File:
; Vector table
LR_VECTOR_TABLE 0x08000000 0x00000200
    ER_VECTOR_TABLE 0x20000000 0x00000200
        *.o (RESET, +First) ; Vector table location in RAM.
; load region size_region
LR_IROM1 (0x08000000 + 0x00000200) (0x00080000 - 0x00000200)
    ; load address = execution address
    ER_IROM1 (0x08000000 + 0x00000200) (0x00080000 - 0x00000200)
        *(InRoot$$Sections)
        .ANY (+RO)
        .ANY (+XO)
    ; RW data
    RW_IRAM1 (0x20000000 + 0x00000200) (0x00040000 - 0x00000200)
        .ANY (+RW +ZI)
Default Keil/STM Cube MX stack and heap setup in "startup_stm32l552xx.s":
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; <h> Stack Configuration
; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Stack_Size EQU 0x00002000
AREA STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem SPACE Stack_Size
__initial_sp
; <h> Heap Configuration
; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size EQU 0x00001000
AREA HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem SPACE Heap_Size
__heap_limit
0
