Hello everybody, I have a question regarding the Region$$Table$$Limit value.
I have following simple scatter file:
LR_1 0x08000000 0x100000 { ER_RO 0x08000000 0xffffffff { *.o (RESET, +First) *(+RO) *(InRoot$$Sections) } ER_RW 0x20000000 0xffffffff{ *(+RW) } ER_ZI 0x20001000 0xffffffff { *(+ZI) } }
after compiling and linking I'm getting these values related to Region$$Table:
Region$$Table$$Base 0x080003b0 Number 0 anon$$obj.o(Region$$Table) Region$$Table$$Limit 0x080003d0 Number 0 anon$$obj.o(Region$$Table)
also I have some test variables:
0x20000000 0x080003d0 0x00000004 Data RW 4 .data.a main.o 0x20000004 0x080003d4 0x00000004 Data RW 5 .data.c main.o 0x20000008 0x080003d8 0x00000004 Data RW 6 .data.d main.o
and init function called from my startup code:
void init(void){ int limit = Region$$Table$$Limit; void** size = &Region$$Table$$Base + 2; int __rw_len = ((int)*size)/4; int __rw_start = (int)Region$$Table$$Base; main(); }
So Region$$Table$$Base points to correct address of the data to be copied, but the Region$$Table$$Limit, as far as I know should point to the address of the byte beyond the end of the section which is 0x080003dc (after .data.d variable from the second code) but it points to itself 0x080003d0 so i'm getting the value of .data.a variable instead of the address of the byte beyond, so I can't really tell where this section to be copied to ram ends.
So if I'm missing something I will appreciate any thoughts.
Ok so my bad, it's like Region$$Table$$Base value coresponds to the end of the ER_RO section.
So to know the limit of the data to be copied to ram you have to use
extern int Load$$ER_RW$$Limit[];
I thought that this is the purpose of the Region$$Table$$Limit symbol.
