i use a STM32F101C8 Controller and µVision Keil IDE.
I have a program that works fine. A code change crashes the controller (probably because of writing in wrong flash areas).
To get the controller back to life i did a Flash->Erase followed by a download of my program.
After that writing/clearing Flash pages dont work proberly anymore.
First of all my Powerfail-Interrupt Routine dont works anymore. The area im writing to contains always 0xFF after i power on/off the controller.
Next weird behaviour is when i erase a flash area the microcontroller it crashes. A power off/on wont bring the controller back. Only a Flash -> Erase and download of program in the µVision IDE fixes the problem.
I use address 0x08006000 as offset and count pagewise from there.
All works fine until i choose Flash->Erase in the Keil IDE.
Did someone inspect same behaviour and can help me out why that happens?
Thanks for your response
