Hi
I have a set of Editor Code templates
https://www.keil.com/support/man/docs/uv4/uv4_ui_templatestab.htm
I want to share it within a team. How do I do this ? Where are templates stored ?
Unfortunately the text templates you are referring to are stored locally on your PC. There is no way to export them and import them again on another PC.
However, you may consider using user code template, as described here developer.arm.com/.../latest
"There is no way to export them ..."
Hm, very saddening.
"text templates you are referring to are stored locally on your PC"
Where ?
Thank you
