When I was debugging, I ran into the difficulty above.I don`t know where to found the sarmcm4.dll.
I would be very grateful if this problem could be solved.
- Should be located in the \Keil5\ARM\BIN directory
- Probably you haven't completely installed MDK 5:
http://www2.keil.com/mdk5
what ?MDK is not fully installed?I can already run programs normally in MDK5,But when I burn binaries to my development board through JLink, it reports this error。Do I need to uninstall MKD5 and reinstall it?
At least - for some reason - this file is missing.
As it is part of MDK5 a new installation should result in its returning.
(There is no uninstallation of MDK required)
I have reinstalled it but the problem is still not solved。
I still can't find the sarmcm4.dll,I used STM32F103 before,But now I use STM32F401.So I need sarmcm4.dll
Sorry, I just got it now - it must be a typo because the file we talk about is called:
sarmcr4.dll
(there never has been a file sarmcm4.dll)
Looking great work dear, I really appreciated to you on this quality work. Nice post!! greatpeople
