Dear Sir, May I leanr the meaning of the L?xxxx ? Where could I find the description of M51 in KeilC? Thank you.
C:32E1H SYMBOL L?0506 C:32E4H SYMBOL L?0507 C:32EBH SYMBOL L?0512 C:32F8H SYMBOL L?0513 C:32FBH SYMBOL L?0514 C:3303H SYMBOL L?0517 C:3303H SYMBOL L?0518 C:330AH SYMBOL L?0521 C:3332H SYMBOL L?0522 C:3332H SYMBOL L?0523 C:3334H SYMBOL L?0524 C:3335H SYMBOL L?0525 C:333BH SYMBOL L?0529 C:333FH SYMBOL L?0530 C:3349H SYMBOL L?0532
That would be in the documentation:
http://www.keil.com/support/man_c51.htm
The map file is produced by the Linker, so the Linker Manual would be the one you require:
http://www.keil.com/support/man/docs/bl51/bl51_in_listing.htm
The L?xxxx symbols are labels internally generated by the compiler.
