I am developing a project using Infineon IC SP370. It has in-built 8051 microcontroller. I am using Keil IDE to develop the code for this chip. When creating a new project, for chip selection, this SP370 IC is not available. Will Keil IDE support this IC to develop the code?
It will generate the 8051 code.
You will have to manually set up the configuration.
I would suggest that you contact Infineon for support with that ...
