Hi there,
I have faced a problem with the NGX/NXP LPC1837 LPCXpresso board. The board is supplied with LPC1837 microcontroller connected to the LAN8720 PHY. I am using Keil uVision5 with the CMSIS drivers. I was following the example code from the CMSIS website:
www.keil.com/.../group__eth__interface__gr.html
so my Initialization code looks as follows:
static __inline void InitializeOnChipEthernetMAC(void) { MAC = &Driver_ETH_MAC0; PHY = &Driver_ETH_PHY0; capabilities = MAC->GetCapabilities(); MAC->Initialize(ARM_ETH_MAC_SignalEvent); MAC->PowerControl(ARM_POWER_FULL); if (capabilities.mac_address == 0) { MAC->SetMacAddress(&own_mac_address); } else { MAC->GetMacAddress(&own_mac_address); } if (PHY->Initialize (MAC->PHY_Read, MAC->PHY_Write) == ARM_DRIVER_OK) { PHY->PowerControl (ARM_POWER_FULL); PHY->SetInterface (capabilities.media_interface); PHY->SetMode (ARM_ETH_PHY_AUTO_NEGOTIATE); } while (true) { if (PHY->GetLinkState() == ARM_ETH_LINK_UP) { break; } } }
Unfortunately, I am getting timeouts inside the PHY->PowerControl function. Mainly inside the PHY_LAN8720.c file (v6.2) at line 139 the function call
PHY.reg_rd(ETH_PHY_ADDR, REG_PHYIDR1, &val);
always returns ARM_DRIVER_ERROR_TIMEOUT. I have enabled the systick timer in the RTOS v1 which I am using. Has anyone had a similar issue and could tell me what I am missing?
