hi everybody i have a assembly program and want to use it in my project . but keil don't compile this directly. i don't have enough knowledge to correct and convert code to keil could compile this code. pls help me tnx alot
.syntax unified #ifdef __ARM_PCS_VFP @ High-throughput block transfer using the FPU register set as a 128-byte @ buffer. @ @ This implementation exploits the IT Folding feature of the Cortex-M4. @ An IT instruction following a 16-bit Thumb instruction, when both are @ aligned into a 32-bit memory word, takes no additional cycles to issue. @ @ Arguments: @ r0 source address @ r1 destination address @ r2 number of words to transfer. .section .ramcode,"ax",%progbits .balign 4 .global _Z10copy_wordsPKmPmm .thumb_func _Z10copy_wordsPKmPmm: @ Name our registers. src .req r0 dst .req r1 count .req r2 @ The caller may have been using floating point. @ Save the callee-save portion of the register file. vpush {s16 - s31} @ 17 @ "Warm up" the transfer engine, which wants to operate in units of @ 128 bytes, by making smaller transfers until count a multiple of 128. @ Special-case the single word transfer; the macro below won't work. lsrs.n count, #1 @ 1 itt cs @ 0 (aligned) vldmcs.32 src!, {s0} @ 2 vstmcs.32 dst!, {s0} @ 2 @ Transfer n+1 words. .macro XFER n @ 5 + 2*n lsrs.n count, #1 @ 1 itt cs @ 0 (aligned) vldmcs.32 src!, {s0 - s\n} @ 1+1+n vstmcs.32 dst!, {s0 - s\n} @ 1+1+n .endm XFER 1 @ 7 XFER 3 @ 11 XFER 7 @ 19 XFER 15 @ 35 @ Handle the case where we've been asked to transfer <32 words. @ In such a case, count will now be zero, and the Z flag will still @ be set from the last XFER. @ @ Force the branch to use a 32-bit instruction to preserve alignment @ of the loop branch below; this saves a cycle per time that branch @ is taken. @ @ Note that the target of this branch (at 1 below) is also aligned, @ saving a cycle on the rare escape path. beq.w 1f @ 1 (n.t.) @ All warmed up, transfer in units of 128 bytes. 0: vldm.32 src!, {s0 - s31} @ 33 vstm.32 dst!, {s0 - s31} @ 33 subs.n count, #1 @ 1 bne.n 0b @ ~3 (taken) @ Restore FPU state. 1: vpop {s16 - s31} @ 17 bx lr @ 1-3?? #else #error copy_words is not available for your architecture. #endif
