I have a Keil uvision 5 and currently using for ARM-Cortex-M4 for compiling sources.
I am using C language files. Can I use C++ files or library in this environment and access the definitions.
Is mixing C and C++ possible?
Thanks,
It's possible to mix C and C++. But requires that you understand the differences between them and what is and what isn't compatible.
A C++ function can always call a C function (as long as it knows the target is a C function).
A C function can only call a C++ function that has been specified to use the C calling/naming convention.
But there are other things too - like a C function can obvisouly never catch a C++ exception. And while C++ uses new/delete, C uses malloc()/free().
