Hi, I have downloaded a example of a bootloader for the board A2F500M3G.
The example contains two .s files, but uvision can't compilate them.
File 1:
.text .global bx_3rd_eNVM_Image .code 16 .syntax unified .type bx_3rd_eNVM_Image, function
.equ VECTOR_TABLE_ADDR, 0x00020000
.align 4
bx_3rd_eNVM_Image: ldr r0,=VECTOR_TABLE_ADDR ldr r1,[r0,#0x0] movw r2,#0xED08 movt r2,#0xE000 str r0, [r2, #0] ldr lr,[r0,#0x4] msr msp,r1 bx lr .end
File 2 is very similar to File 1.
I obtain several errors like: bx_3rd_eNVM_Image.s(9): error: A1137E: Unexpected characters at end of line bx_3rd_eNVM_Image.s(50): error: A1167E: Invalid line start bx_3rd_eNVM_Image.s(51): error: A1517E: Unexpected operator equal to or equivalent to *
I think the format of this files aren't the correct to compile or it is possible that I am missing some option.
I am a bit lost, can you help me?
Thanks you very much.
Hello! I have a similar problem.
I am trying to compile a Demo Blinky programm and created an empty project and imported all the files, and all the c-files compile but the .s file won't.
I am using
* uVison MDK-Lite 5.23 * STM32F103R6
The error message is: (50 Errors all similar)
assembling startup_stm32f103x6.s... startup_stm32f103x6.s(46): error: A1137E: Unexpected characters at end of line ....
I asked Dr. Google, but all I found out is that it may have to do with
--cpreproc
or
a Legacy Problem
I tried both (using the option --cpreproc and installing the legacy addon)
but still there are 50 Errors ...
Can anyone help?
Best regards, Max
