hi.i have debug problem.
i want to debug NXP LPC812M101 (NXP OM13069) use jlink v8 in keil 4.73
cannot access taregt shutting down debug session
How do I solve the problem ?
PS. i sue SWD to debug
You're going to have to a) make sure you have the connection wired up properly b) make sure the device isn't going into a sleep mode, or powering down
can i use lpclink2 to debug on keil ?
Which option should I choose?
Hi
Below link should be helpful: www.lpcware.com/.../using-lpc-link2-keil
If the jumpers position is correct then in uVision you would have to select "CMSIS-DAP
THX . i jlink had debug over.
but i use CMSIS-DAP can not found chip. what can i do ?
i use lpc812m101
Still pointing to a connectivity or power issue. What have you done to resolve that?
Perhaps you can explain your board design and connectivity with some more rigor?
Check the voltages. Check the state of NRESET/NRST.
