I followed the following:
http://www.keil.com/support/docs/3632.htm http://www.keil.com/support/docs/3266.htm http://www.keil.com/support/docs/2937.htm
But none really seem to address my issue.
Using: - Windows 7 Professional - uVision V5.17.0.0 - Ulink2 ordered 1-2 weeks ago
Problem: - Plugging in Ulink2 turns on the USB light (COM and RUN remain off, but flash briefly upon being plugged in) - Windows recognizes the device, but nothing actually happens. In uVision, all the drop-down menu contents are greyed out (For example, "Flash" shows 'Download', 'Erase', 'Configure Flash Tools', all of which are greyed out) - Following the links above, I tried a bunch of things, but the actual situation doesn't change - In Device Manager under Human Interface Devices, there are two listings 'HID-compliant device' and 'USB Input Device' -- when I run Update Driver, I get 'Windows has determined the driver software for your device is up to date' after a long search
How can I resolve this?
Perhaps you could contact technical support? Speak to your local IT mopes?
If you think the pod is defective, seek a replacement. I'd recommend trying it on a different system, I've heard complaints about DELL USB3 ports, and I would also check if AV or company policy settings impact the installation of drivers and USB attached peripherals.
I have ULINK2 pods working on Win7 x64 machines, so I think you need to focus on what's different or out of place on your installation.
This is awesome. Thank you very much for sharing.
Following your suggestion, I've contacted tech support. It's also helpful to know that you've got it running.
Cables are also a big point of failure.
work with Ulink2 without update firmwork in Keil 5.x
i worked with Ulink2 and i have very problem in keil 5 series. i solved that problem :
first install keil 4.7 go to setup destination /Arm / BIN copy this 6 files : UL2ARM.dll UL2CM3.dll ulinkpro.bin ulinkprod.bin ULP2ARM.dll ULP2CM3.dll
then uninstall the keil 4.7 and install keil 5.x go to setup destination /Arm / BIN paste & replacement 6 file here go to keil 5 and select ulink2 (debug & utility tab) now you can enjoy with ULINK2
