I've have trouble using DNS Client service from MDK.
I use MDK-PRO 5.0.4 + STM32F4
The PPP is configured so that the "Obtain Client IP" and "Use Default Gateway" PPP option are both checked (but after investigating, nor of those option change anything).
The Primary and Secondary DNS server addresses parameter get the static IP of my two DNS servers.
The PPP is made over a 2G modem with a private APN.
When the link is established with the provider, I can see, using debug facilities, the assigned IP address but also an DNS IP server address (I think that this is the point to my troubles). This DNS IP server is not the one I have inputed in the PPP configuration.
006.6 PPP:*** Processing IPCP frame *** 006.6 PPP: Code : Conf_Ack 006.6 PPP: Id_Val: 0x03 006.6 PPP: Length: 22 006.6 PPP: IP Address: 10.143.133.208 006.6 PPP:Network-Layer Up 006.6 PPP: Prim. DNS : 10.8.0.1 -> NOT THE GOOD ONE 006.6 PPP: Sec. DNS : 0.0.0.0
So this result in a DNS Client query that always ends up in timeout status :
235.9 DNS:Resolve "xxx.yyy.jcdecaux.com" 235.9 DNS:Send request to Server 235.9 DNS: Serv.IP: 10.8.0.1 -> NOT THE GOOD ONE 235.9 DNS: Tran.Id: 0x1770 235.9 DNS: Flags : 0x0100 235.9 DNS: QdCount: 1 235.9 DNS: AnCount: 0 235.9 DNS: NsCount: 0 235.9 DNS: ArCount: 0 235.9 PPP:Sending frame 235.9 PPP: Protoc: IP 235.9 PPP: Length: 77 236.9 DNS:Retransmitting request 236.9 DNS: Serv.IP: 10.8.0.1 236.9 DNS: Tran.Id: 0x1770 236.9 DNS: Flags : 0x0100 236.9 DNS: QdCount: 1 236.9 DNS: AnCount: 0 236.9 DNS: NsCount: 0 236.9 DNS: ArCount: 0
and then ...
252.9 DNS:Retransmitting request 252.9 DNS: Serv.IP: 10.8.0.1 252.9 DNS: Tran.Id: 0x1770 252.9 DNS: Flags : 0x0100 252.9 DNS: QdCount: 1 252.9 DNS: AnCount: 0 252.9 DNS: NsCount: 0 252.9 DNS: ArCount: 0 252.9 PPP:Sending frame 252.9 PPP: Protoc: IP 252.9 PPP: Length: 77 254.9 DNS-ERR:Resolve, Timeout expired
The same program using the ethernet interface in place of the PPP one is ok.
So, is there's a way to change dynamically the DNS server address so that it can be pointed to the correct one or there is no solution top this problem ?
Alain.
