Hello, I´ve got a big problem with my µvision project for the LPC54102J512. If I have initialized the clock for any peripheral of the asynchronous block once there is no way to start a debug session. I only enabled the clock for the IOCON block, the clock for GPIO-Port0 and -Port1, asserted a reset at both GPIO-Ports, defined Pin0_29 as GPIO, set its direction as output and toggled the state of the GPIO-Pin in a loop. If there is no access to the asynchronous block it works fine. Only if I enabled the clock for SPI or I2C and started the debug session, nothing works. Here´s my code of the main.c:
main.c
#include "LPC54xxx.h" #include "cmsis_os.h" int main(void) { if(!osKernelRunning()) { //Aufruf dient der Kompatibilität gegenüber späteren CMSIS-RTOS Versionen if(osKernelInitialize() != osOK) //initialize CMSIS-RTOS { //TODO: Fehlerbehandlung, Initialisierung fehlgeschlagen } } osKernelStart(); //start executing // LPC_ASYNCSYSCON->ASYNCAPBCLKCTRLSET |= (1 << 5); //enable clock for I2C // LPC_SYSCON->AHBCLKCTRLSET0 |= (1<<13); //enable access to IOCON block // // LPC_SYSCON->AHBCLKCTRLSET0 |= (1<<14); //set clock for GPIO-Port 0 // LPC_SYSCON->AHBCLKCTRLSET0 |= (1<<15); //set clock GPI0-Port 1 // LPC_SYSCON->PRESETCTRLSET0 |= (1<<14); //Reset GPI0 Port 0 // LPC_SYSCON->PRESETCTRLCLR0 |= (1<<14); //Clear Reset GPIO-Port 0 // LPC_SYSCON->PRESETCTRLSET0 |= (1<<15); //Reset GPIO-Port 1 // LPC_SYSCON->PRESETCTRLCLR0 |= (1<<15); //Clear Reset GPIO-Port 1 // // LPC_IOCON->PIO0_29 &= ~(0x07<<0); //define Pin0_29 as GPIO // LPC_GPIO->DIR0 |= (1 << 29); //set direction as output // osKernelStart(); //start executing while(1) { // LPC_GPIO->PIN0 |= (1 << 29); // osDelay(500); // LPC_GPIO->PIN0 &= ~(1 << 29); // osDelay(500); }; }
