Two files with the same name -> compile error
Project has two files with the same name "timers.c". One is from LwIP and another from FreeRTOS. Compilier returns warning and errors.
Warning: L6304W: Duplicate input file .\debug\timers.o ignored.
Error: L6218E: Undefined symbol sys_timeouts_mbox_fetch (referred from tcpip.o).
Error: L6218E: Undefined symbol sys_timeouts_init (referred from init.o).
Error: L6218E: Undefined symbol tcp_timer_needed (referred from tcp.o).
My solution is to rename one of files. But it is a bad practice since third-party libs should be unchanged.
Is there way to change output name for only file?
  • Sorry, I don't think there is a simple work-around for this. What happens if you build one of the above libraries separately, and just link your project with the library file?
    This is a situation where Keil still suffers from their herritage. In the 8051 world, few people bought libraries, and most projects was small with a quite limited number of source files.
    But many of todays ARM microcontrollers are more similar to the Intel i486 processor - a processor that when introduced was much used in very expensive corporate servers.
    Keil really should start to produce a full output directory tree to avoid object file name collisions.
  • Keil really MUST start to produce a full output directory tree to avoid object file name collisions. Projects grow as grass...
  • Compiling libraries is not the way. I frequently look to their sources to understand how it works, and take ideas for future code. Sometimes it is useful to compile library with DEBUG flags (for example UDP_DEBUG) to debug my higher level modules.
  • With a couple of exceptions, I too seldom use libraries with Keil, but when I use with other environments, I can have both release and debug builds of the library - and the debug builds contain debug information so the debugger can find the source code.
    On a PC, you practically always link library files.
    Next thing is that linking a library file doesn't stop you from looking at the library source code.
  • Thank you. It seems like you have good experience. I'm going to do as you tell.
