This may not be a big doubt or querry but kindly have patience.
I m using fopen with nand flash memory. when is perform
FILE* file; char filepath[PROTO_FILEPATH_SIZE]; ... file = fopen(filename, "w"); //filename = "Docs\CBE renamed.txt" ...
fopen creates a file with the name 'CBD renamed' in the folder Docs (no .txt extension). for any other filename without space characters, file is created with the extension '.txt'
kindly advise
I don't use the Keil file system - but what file system is it. If it's a traditional MS-DOS file system without VFAT support, then file names are limited to 8.3 length.
This is a little bit of text about the file name handling - actually about # of files you can store in the root directory, but it does mention a bit about processing of file names.
http://www.keil.com/support/docs/3598.htm
That would be Flash-FS. but on Parallel Nand flash memory, i think its FAT32. (though i m not sure about the details. i havent really implemented it _but welcome all the suggested documents - for studying and getting the details of it_)
