Hi, Today I started working with a Cypress EZ-USB FX Development Board. I downloaded devtools version 2.61 After I connected my board to the computer I run EZ-USB control panel and loaded the target with dev_io.hex. I tested it and everything worked just fine. Then I wanted to test the same program in Keil uVision2 V2.10, but without succes. Everytime when I want to go to Debug mode, I get a message that says: Try Again! I've checked the cables and the settings, but I could not find any mistakes. Has anyone had the same problems as I am having now? Kind regards, Chris
Does this knowledgebase article help? http://www.keil.com/support/docs/2353.htm Jon
